This old orginal no display.plz fixPlz.i need bios okay samsung chromebook XE930QCA factory image
Thank you working 100%Samsung chromebook XE930QCA
Board: BA41-02769A
CLEAN ME BIOS
When wrong bootable flash then give same error.I downloaded the system using a recovery flash drive, but the process completed successfully without booting into the system; only this message appeared.
The same error doesn't appear; I mean, the error isn't with the flash drive or the boot process. I downloaded the system using the device's code, and everything is fine and completes the installation steps successfully, but it doesn't boot into the system, or rather, it doesn't recognize the boot or the hard drive. I think there's an error in the BIOS file.When wrong bootable flash then give same error.
Follow same model amd format 32 after try
sir no display plz build
processor/srgky
sir this bios didn't work , please rebuild it... thanks
