Programmer Successor Base 2 Available
Browse all 33,419 files →
Programmer Successor Base 2 Available – 1707510800397Programmer Successor Base 2 Available – 1707511139816
Programmer Successor Base 2 for SPI FLASH memory and EC firmware
Programmer successor base 3 for SPI FLASH memory and EC firmware
Dilevery available all over the world Contact on Whatsapp: +923280493988​
Files for the Programmer Successor Base 2 Available motherboard.
I purchased successor base 3 from you i need software for this programmer
if you are using the programmer for the first time, then you need to do the following:
1 Connect programmer to PC
2 Run the file AUTO_driver_X86_X64_install.bat and wait.
The driver is installed once.
3 If you are asked about installing the driver - confirm.
4 The Jungo Connectivity folder will appear in the device manager,
and in it there are two devices named:
WinDriver1400
SUCCESSOR
5 Now you can run the program and work.
SUCCESSOR BASE 3 SOFTWARE.rar
Hey i purchased this successor base 4 programmer and today i received it. Thank you admin and all team.
Now i want to install latest software please upload latest software here
Programmer Successor Base 2 Available – 1771322500584
1. Connect programmer to PC
2. Run the file AUTO_driver_X86_X64_install.bat and wait.
3. If you are asked about installing the driver - confirm.
4. The Jungo Connectivity folder will appear in the device manager,
WinDriver1400
SUCCESSOR
5. Now you can run the program and work.
SUCCESSOR BASE 4 17.6 31-1-26.rar
WinDriver1400
SUCCESSOR
Thanks working ok
