STANDBY IC MP2314SGJ-Z IARDN- IARDR CODE
Laptop Motherboard Standby IC Datasheet
Browse all 33,423 files →
The MP2314S is a high-efficiency, synchronous, rectified, step-down, switch mode converter with built-in, internal power MOSFETs. It is a next generation of the MP2314. It offers a very compact solution to achieve 2A continuous output current over a wide input supply range with excellent load and line regulation.The MP2314S uses synchronous mode operation for higher efficiency over the output current-load range. Current mode operation provides fast transient response and eases loop stabilization.Full protection features include over-current protection (OCP), over-voltage protection, (OVP), and thermal shutdown.The MP2314S requires a minimal number of readily available, standard, external components and is available in a compact TSOT23-8 package. Jotrin Electronics is an authorized Monolithic Power Systems distributor.
Feature​
  • Wide 4.5V to 24V Operating Input Range
  • 2A Load Current
  • 120mO/50mO Low Rds(on) Internal Power MOSFETs
  • Low Quiescent Current
  • High Efficiency Synchronous Mode Operation
  • Fixed 500kHz Switching Frequency
  • Frequency Sync from 200kHz to 2MHz External Clock
  • AAM Power Save Mode
  • Internal Soft Start
  • OCP Protection and Hiccup
  • Thermal Shutdown
  • Output Adjustable from 0.8V
  • Available in an 8-pin TSOT-23 package
MP2314.pdf
