HD PHOTOS LA-E921P Rev. 1B (Acer Predator PH317-51)
Browse all 33,423 files →
Scanned "LA-E921P Rev. 1B" motherboard in 1200DPI
HD photos of the LA-E921P main board from the Acer Predator PH317-51. Use them to find burned or missing parts, check component values and compare the layout with your own board.
The board was manufactured by Compal for Acer. Compal board numbers start with LA- and end in P, so you can confirm it on the PCB silkscreen. This listing is for revision 1B; another revision of the same board can need a different file.
If you have a working file for this board, please share it below. More files: search LA-E921P in File Finder.
LA-E921P Rev. 1B (Acer Predator PH317-51) – 2025-02-02-17h-55m_2 LA-E921P Rev. 1B (Acer Predator PH317-51) – 2025-02-02-18h-00m_2
