EC / KBC Unlock · BIOS Patch Unlock MEC17xx, Nuvoton & ITE Unlocked using a BIOS patch · Private check · For verified owners and repair technicians Chat on WhatsApp MEC17xxNuvotonITE
Dell Master BIOS Code Available Dell BIOS Password Recovery Codes Send your System Number · Private check · For verified owners and repair technicians Chat on WhatsApp 8FC8CF1B3FE29ABE1B58E7A8
HD PHOTOS LA-D711P Rev.3.0 (HP 15-ba, HP 250 G4) Scanned HD photos
Browse all 32,631 files →
Scanned Photos of LA-D711P Rev.3.0
(Scanner is HP Scanjet G3010)
Btw... this is the all board for HP 250 G4
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-C701P ("i" CPU 5th gen. with & without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-C811P ("N" CPU without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-C781P (AMD with & without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-D711P (AMD with & without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-D702P ("N" CPU with & without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-D703P ("i" CPU 5th gen. with & without GPU)
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-D704P ("i" CPU 6th gen. with & without GPU) DDR4
HP 250 G4 G5, HP 15AC, 15BA, 15AF, 15AY ------- LA-D707P ("i" CPU 7th gen. with & without GPU) DDR4
High-resolution board photos of the HP 15-ba HP 250 G4 (LA-D711P). Use them to find burned or missing parts, check component values and compare the layout with your own board.
The board was manufactured by Compal for HP. Compal board numbers start with LA- and end in P, so you can confirm it on the PCB silkscreen. This listing is for revision 3.0; another revision of the same board can need a different file.
Have a tested file for LA-D711P? Reply below and help the next technician. Looking for something else? Search all files in the File Finder.
