ASK JH63T LA-L99GP rev 1a schematic
HELLO COMMUNITY, I'M LOOKING FOR THIS SCHEMATIC: PREDATOR HELIOS NEO 16 N23C12 JH63T LA-L99GP 1A.
THE MOTHERBOARD HAD A SHORT CIRCUIT, AND AFTER REPAIRING THE PROBLEM, IT STOPPED CHARGING THE BATTERY. ALL ITS FUNCTIONS WORK PERFECTLY, BUT IT DOESN'T CHARGE. I'VE ALREADY BOUGHT A NEW CHARGER AND BATTERY, AND IT ONLY SHOWS AS IF IT'S CHARGING, BUT THE CHARGE LEVEL NEVER INCREASES. I WOULD GREATLY APPRECIATE HELP FROM ANYONE WHO HAS HAD A SIMILAR PROBLEM. THANK YOU VERY MUCH.
This thread is for the JH63T with main board LA-L99GP.
Compal board numbers start with LA- and end in P. Check the number printed on the PCB before you download. This listing is for revision 1A; another revision of the same board can need a different file.
If you have a working file for this board, please share it below. More files: search LA-L99GP in File Finder.
JH63T LA-L99GP rev 1a schematic – WhatsApp Image 2025-12-18 at 11.17.21 AM (4) JH63T LA-L99GP rev 1a schematic – WhatsApp Image 2025-12-18 at 11.17.21 AM (3) JH63T LA-L99GP rev 1a schematic – WhatsApp Image 2025-12-18 at 11.17.21 AM (2) JH63T LA-L99GP rev 1a schematic – WhatsApp Image 2025-12-18 at 11.17.21 AM (1) JH63T LA-L99GP rev 1a schematic – WhatsApp Image 2025-12-18 at 11.17.21 AM
Charging ic name?
You check all volt requirment charging ic?
Charging ic name?
I haven't checked the voltages yet. I was looking for the schematic diagram to verify the value of some resistors. The integrated circuit is the BQ24800.
