LENOVO IdeaCenter A560-24ALC - A560 24ALC NM-D641
Browse all 32,388 files →
Lenovo A560-24ALC - A560_24ALC - NM-D641 Schematic And BoardView PDF
NM-D641 BoardView PDF.pdf
A560-24ALC R
A560-24ALC REV01.pdf
Hello, having a doubt, looking at the Lenovo A560_24ALC mainboard, on which is the flash on which to program the Bios if the 25X20cl, marked on the mainboard as ECU2, or the 74M12 marked as SBU1, I would be grateful if you could kindly send me via email an image of said mainboard with the flash to be programmed indicated above.
Thank you and best regards.
acampanozzi@libero.it
Flash Main 16MB Bios on SBU1
Thanks for your help. I bought a CH341A programmer with 1.8 volt adapter and an EZP2923 programmer on Aliexpress.
Will I be able to program the W74M12jwsiq chip with the above programmers or do you recommend another type of programmer. Thanks again
Use CH341A
