BIOS HP OMEN 16-wf0032TX JPR6F LA-M783P Rev 2.0
HP OMEN 16-wf0032TX (81L09PA) JPR6F LA-M783P Rev 2.0 08BA8 DMI Bios
HP OMEN 16-wf0032TX LA-M783P
CLEAN ME
16MB BIOS
BIOS BID 08BAA
ENE KB9542QG 160KB
SRMEC (Intel Core i9-13900HX)
Hola señor, tu puedes reparar mi BIOS que no detecta ningún SSD en las 2 ranuras M.2. HP OMEN 16 LA-M786P.
Señor sigue con el mismo problema con los 2 archivos que enviaste. En la Web de Vinafix no pudieron reparar este daño por eso busque otro Admin. Gracias de todas maneras
Send photo bios setup where is not show.
press f9 and check
Everything for EC ENE KB9542QG I am guessing you are correct on the file size, I had to order a new chip as I think this one is toast, it will not read in the SVOD4 ZIF socket
Ene KB9542QG size is 160kb
Not 128kb or 256kb
Above first post avaiable 160kb
The EC above in first post is entire different machine although same MB with my BIOS being an 8CC0
The EC code didn't work, no charge light and power light turns on and then off :(
Dang it. I REALLY HATE EC. Errors on verify write at 49%. sigh Thanks for the help.... Pointless now...
