ASK GIGABYTE B650M PLUS WIFI REV 1.1
Browse all 33,449 files →
Hello, customer flashed via qflash to accommodate the 9000 series, and I think customer didn't allow to finish and now motherboard turns on then off. I have attached what I believe to be a corrupted bios from the chip. Can you please make a new factory bios if possible with the latest update. I have also attached that latest update from the support site.
Files for the Gigabyte B650M PLUS WIFI motherboard.
Compare the board number printed on the PCB (between the PCIe slots or near the CPU socket) with the files before you flash. This listing is for revision 1.1; another revision of the same board can need a different file.
If you have a working file for this board, please share it below. More files: search Gigabyte B650M PLUS WIFI in File Finder.
Hahahaha piece of junk Gigabyte, went to flash your image and the chip failed instantly on
Start blank check in: 6/3/2025 2:37:17 PM
error
address: 1000
buffer: FF device: AA
Blank Check false
error
address: 1000
Blank Check false
i think this error related to chip clean bios chip use liquied and put back.
