Scanned LA-H323P Rev.1.0 board
I'm still collecting information for HP 250 G8 boards
This is for now:
HP 250 G8, HP 15-dw, 15s-du,15s-dr ------ LA-H323P Rev.1.0 ( "i" 8-th & 10-th gen. DIS & UMA)
HP 250 G8, HP 15-dw, 15s-du,15s-dr ------ LA-H325P Rev.1.0 ("N" CPU, DIS & UMA)
HP 250 G8, HP 15-dw, 15s-du,15s-dr ------ LA-H329P Rev.1.0 ("i" CPU 10th gen. only UMA)
If you have information to add boards for this list, send me a message.
I will gladly add.
This is for now:
I will gladly add.
High-resolution board photos of the HP 250 G8 HP 15-dw 15s-du 15s-dr (LA-H323P). Use them to find burned or missing parts, check component values and compare the layout with your own board.
The board was manufactured by Compal for HP. Compal board numbers start with LA- and end in P, so you can confirm it on the PCB silkscreen. This listing is for revision 1.0; another revision of the same board can need a different file.
Have a tested file for LA-H323P? Reply below and help the next technician. Looking for something else? Search all files in the File Finder.
