Scanned Photos of LA-G07JP Rev.2.0
Btw... this is the all board for HP 250 G7
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G07JP (AMD CPU)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G078 (AMD CPU)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G073P ("N" CPU FCBGA1090)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G074P ("N" CPU FCBGA1170)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G07FP ("I" 8th with & without GPU)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-G07DP ("I" 7th with & without GPU)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-J951P ("I" 10th without GPU)
HP 255, 250, 256 G7 HP 15-DB, DA ---- LA-J952P ("I" 10th with GPU)
High-resolution board photos of the HP 255 G7 (LA-G07JP). Use them to find burned or missing parts, check component values and compare the layout with your own board.
The board was manufactured by Compal for HP. Compal board numbers start with LA- and end in P, so you can confirm it on the PCB silkscreen. This listing is for revision 2.0; another revision of the same board can need a different file.
Have a tested file for LA-G07JP? Reply below and help the next technician. Looking for something else? Search all files in the File Finder.
