ASUS GU502DU (REV 2.0) HD Photos
Browse all 33,399 files →
HD photos for ASUS GU502DU (REV 2.0)
High-resolution board photos of the Asus GU502DU. Use them to find burned or missing parts, check component values and compare the layout with your own board.
Compare the board number printed on the PCB (near the RAM slots or under the battery) with the files before you flash. This listing is for revision 2.0; another revision of the same board can need a different file.
